other brands ok here ya go
k1500chevy97
other brands besides the chevy we have ... well lets list them all
2) 1994 dodge dakotas 3.9 auto 2wd long bed reg cab
1) 1993 dakota 3.9 auto 2wd reg cab long bed
1) 1998 dakota 3.9 auto ext cab short bed 2wd
1) 1996 dodge 1500 318 auto 4x4 ext cab short bed
1) 1976 dodge 1 ton 360 auto flatbed diesel fuel truck 2wd
1) 1986 dodge ramcharger 318 auto 4x4
2) 1987 chevrolet s-10s 2.8 auto long bed reg cab 2wd
1) 1995 chevy s-10 reg cab long bed 4.3 auto 4x4
1) 1996 chevy s-10 ext cab short bed 2.2 auto 2wd
1) 2000 chevy silverado 1500 reg cab long bed 5.3 auto 4x4
1) 2002 chevy silverado 1500 reg cab short bed 4.8 auto z71
1) 1994 chevy c-1500 reg cab long bed 2wd auto 5.0
1) 2001 jeep cherokee classic 4.0 auto 4x4
1) 1998 ford f-150 5.4 auto 4x4 reg cab long bed
1) 1999 ford f-250 7.3 auto 4x4 crewcab short bed
*edit*  also put these in the general disc . other vehicles thread
I also have:
*2002 Ford Explorer XLT
(It's my wifes (2 kids) suv, good for 7 people. The Tahoe was just to big for her to drive.)
4.0 V6
Loaded
*1990 Dodge D150 (it is mint, was my Dads since new, garage kept)
-short box/ cab,
-PW/PL
-cold air
-150,000 miles
-318 V8
-manual
