FRAM SureDrain
Which SureDrain model fits the 5.3L?   Website does not show it and AutoZone did not know.
SD4 for the '99 and '00's.  The Fram website doesn't list one yet for '01 and up.  I really don't see why they would be any different than the '99-'00's, but you never know.  You can find it by going to their "parts catalog", then filling in the appropriate info for your truck.
:D
Thanks for the quick reply. I will check out the website. I wouldn't think a drain plug hole would be something that would change...but.....;)
I got one for my '00.  I have mixed feelings on it.  The good thing is that I didn't get a single drop of oil on my garage floor using it (I punched a hole in the bottom of the oil filter with an awl and drained it before removal).  But, the oil drains VERY slowly out of the pan with the Sure Drain hose.  It was nice to be able to drain directly into the container rather than an oil pan though.  My suggestion is to lube the truck while it is draining.  It will take you MUCH longer to lube the truck than to drain the oil...even at the slow pace of the Sure Drain.
Just my 2 cents worth.
B.J.
Did you have the oil filler cap removed while draining?  If it is off, it should drain faster?
The SureDrains look pretty cool and mess-reducing, but I hear that the screw doesn't have a magnet on the end of it to collect any of the metal shavings that the OEM screw collects.  I could be wrong though, that's what I heard through the grapevine!  ???
Yes, I had the oil fill cap removed while draining.  I learned that trick a couple years ago.
And yes, the sure-drain doesn't have a magnet to collect the metal shavings.  That was the one thing I wasn't sure about when I decided to buy it.  But, I have never seen any metal shavings on any of the drain plugs I have ever pulled out of my trucks before so I figured that I would give it a shot.
B.J.
  • 4 months later...
    Brendan C
    Brendan C
  • Who's Online   4 Members, 1 Anonymous, 1,163 Guests (See full list)
