Diablo Predator
U7194 with data cable. 200 shipped in usps standard flat rate box. If you want it shipped or insured, it will be 200 plus what ever that cost. Yes it is "unlocked" as well.
  • 3 weeks later...
Sry, been away.... Yes still have, no on the 2010 I think......and I replied to the last posters email
I don't believe it will work in your 09. The update required for you 09 takes up more memory than the diablo came with. :lol:
Just make sure it will work 100% before you purchase. I ran into that issue when I sold my diablo to a fellow member who had an 09.
oh? i just looked up the number in his ad and checked it on the diablo website and it does say 09 5.3 ltr? im not sure how else to look into this?
Yes, it's the same model number, but you need to check your Software or Firmware version to see if it works on an 09.
U7194
rev 8r01
* Release revision
rev r02
* Fix for backup on 6.2L motors and addition of support for Y 6.0L motors
rev r03
* Added tire size adjustment, cags and speed limit parameters
* Fix for speed limit not being turned off on certain cals
rev r04
* Fix issue with J,3 and 0 motor speed limiter not displaying proper speeds
* Support for old 6.2L 8 motor calid.
rev r05
* Internal change, NO TUNE CHANGES
rev r06
* Fix for custom tune import
rev r07
* Support for 4.8L C motor
* Added header and 91 octane tunes for C6
rev r08
* Support for new 6.0L K and 5.3L M motors s/w
* Support for MY08 trucks
* DoD disable added as a parameter
rev r09
* Fix for not seeing old M cals and applying new cal thus causing no start, restore backup solved it, this update will not support the first M cals made
rev r10
* Fixed issue with 08 Y motor support
rev 9r01
rev 9r02
* Custom parameter fix
rev 9r03
rev 9r05
* Support for 08 LS3/LS7 Corvette added
rev 9r06
* Support for 2009 models
* ALL truck tunes revised for better wot shifts and better fuel economy
rev 9r07
* Support for MY2009,accidentally removed in t05a
* 07 6L Y and K motor added back in
rev 9r08
* added support for 2008-2009 Pontiac G8, GT and GXP,2010 Chevrolet Camaro LS3 and L99, more complete support for MY2009
* support for up to 5 custom tunes, custom tunes will use DSDL and new CMR.
* Custom parameter changes for all applications:*Spark adjustment changed from percent to actual degrees and rpm ranges changed to, 1k-3.8k, 4k-5k, 5.2k-7k *Fuel adjustment rpm ranges changed to, 2k-3.8k, 4k-4.9k, 5k-7k
* Feature implemented where an unsupported OS will be read as a backup so customer can e-mail us their unsupported calibration for quicker turn
around for adding support.
rev 9r09
* Support for many more calid's added in.
    Patrick Fergy
    Patrick Fergy
  • Who's Online   4 Members, 0 Anonymous, 1,175 Guests (See full list)
