8.1 Coolant Change/drain
hey guys trying to change the coolant on this yukon 8.1
the lower hose is a three peice unit with no clamp and doesnt look like it come off very easy.
I found what looks like a drain on the drivers side but theres no flat or phillps head to loosen or open it.
how do i drain this
how do i drain this
I took the coolant resevoir hose off to drain as much coolant as possible. I have a machine with a long hose that I then stuck down the hose to drain the bottom of the radiator. You could use a hand suction pump to drain the rest of the coolant. There is no radiator drain (Brilliant). If you would like to take the lower hose off, you can take a pick and remove the clip that holds the plastic hose fitting in place. Just be sure to move quickly or you will take a Dexcool shower! Good luck.
    Patrick Fergy
    Patrick Fergy
  • Who's Online   4 Members, 0 Anonymous, 1,036 Guests (See full list)
