Charlottesville Va
Mikeee
Looking to move there or nearby.
After our current house sells ... however long that will be ...... ? ? ?
Anyway, we are making a July 4th weekend trip there to kinda scout out the place. I want acreage. Wife wants 2 bedroom cookie-cutter with no lawn. Already we are in disagreement. Anyway, need some general guidance as to areas or nearby towns to begin the search(s).
Wifey, who is the main bread-earner, is looking for hospital related work.
Feel free to open post or PM.
Yea
Yea
Yea
I know....I've not visited in a long time.
Life has been full and busy. Still is but I've gone without my "Forum-Fix" for waaaaay to long.
Thanks.............
Yea
Yea
Yea
Thanks.............
I'm about 60 miles South and spend alot of time on business in Charlotttesville. For beautiful acreage and horse farms, try RT. 15 or RT. 20 areas just outside of Charlotttesville. Several stars have big horse farms in the RT.15 corridor, Robert Duvall, Sisssy Spacek, Christopher(Superman) Reeves. As for the medical side, try UVA Medical Facility. They have many facilities all over and around Charlottesville. On a side note, Charlottesville does have one of the highest cost of living in the Central Virginia area due to all the $$$ that is made and flowing out of the UVA Medical Facilities.
Thanks for the report.
"high cost of ...."
Darn. :)
Also looking for places to stay.
Or....places to avoid.
Econo$$$ is the keyword.
Is there any UVA Medical in Stauton?
We are not married to C'ville, just a starting point for 50-75 mile radius.
Again, thanks.........
"high cost of ...."
Darn. :lol:
Not sure about any UVA facilities in Staunton. Not much of anything in Staunton. Another beautiful area is Waynesboro which is between Charlottesville and Staunton on I-64. This is the heart of the Shenandoah Valley. This is more of a rural area and does have a few medium size medical facilities. Waynesboro is about 25 miles west of Charlottesville.
I hope rural area means less land cost.
Great info ... keep it coming.
Land should be much cheaper in Waynesboro than Charlottesville. Another nice, beautiful and even more rural area is Elkton which is located Northwest of Charlottesville on RT. 33 West. This is also in the heart of the Shenandoah Valley and the Skyline Drive. On a weather note, the "Valley" is pretty, but they usually get hammered hard in the winter when a winter storm moves in, due to being surrounded by mountains.
looking for medical work....
How about Richmond VA, we mcv-vcu medical center that is the equivalent to uva
we have 12 hospitals in the metro area with plenty of rural and suburban areas to choose from.
the cost of living of the area less than the northern VA and maybe about the same as Charlottesville maybe a little less.
most anything that you would like to do, can be done here in the metro area.
good luck on your search.
....How about Richmond VA, ....
Didn't even think about Richmond.
We'll put it on the list.
Maybe even work it in on this weekend trip.
Thanks.........
... usually get hammered hard in the winter when a winter storm moves in, due to being surrounded by mountains.
Hummmm
A whole house generator and a beer fridge....no problem :thumbs:
We'll add Elkton to the visit list.
    liddlera
    liddlera
  • Who's Online   4 Members, 1 Anonymous, 368 Guests (See full list)
    • If you have actually done it, there must be some secret tool or method of accessing the hidden bolt head that both manifold connections have. Two of the three bolt heads are staring at you in the face from below but the third one is covered by shielding and as far as I know only accessed by removing part of the fender well lining to gain access to it and even then its awful to access or from what I had seen of someone fighting with it on a video.    There is a reason why even mechanics that deal with the awkward or risky business of undoing the exhaust at the manifolds have done the same method others are doing with these L8T by flexing the exhaust if need be or just able to slip the pan out as I did without needing to touch hardware or pry on the exhaust. By rights the two seals should be replace when those joints are cracked loose as well.
    • Actually it was a lot more controlled then I thought it might be and that isn't actually when I spilled some oil. I had thought prior of rounding up a couple of longer bolts with the same thread to swap out for a couple of the front edge pan bolts and then leaving one bolt left in the back but loosened off and then using a suction device to remove most of the fluid, that certainly would have worked and while I do have a couple of different devices I could have used to suck the fluid, now having done the job once I wouldn't even bother. I had thought of buying one of those pressurized vessels to suck or new fluid in and would if I was doing a job like this on a few vehicles but with one vehicle I just didn't bother and I have pail pumps as well I could have used assuming the hose end would fit into that less than roomy space but being such a thin fluid it pumped well with a quart type pump and just kept the hose into the trans and kept swapping containers and repeat.    What I would change to the method I did though was first jack up just the rear of the truck to put on jack stands to allow more oil to come out of the check plug on the front of the pan ( and as I did, I made sure to put that drain plug back in finger tight ) then follow through by putting the front on jack stands. Also that I would have used a larger sized drain pan in the sense of covering an area wider/longer beyond the transmission but I didn't have one and saw someone else on a youtube video using a masonry mud mixing tub and bought one at a hardware store to use in the future. The main oopsy  I did and why I spilled some oil was all my fault as I neglected to follow my own plan, I should have let down the pan as I did to drain out the front of it as much as would come out but then scooped out the remainder of the oil with the Dixie cup I had sitting there just for that purpose as by that point there is enough room to reach right into the front of the pan and just bail it out basically.
    • Pretty easy to just remove/drop the exhaust behind the manifolds. They're in no way hard to get to. Maybe 5min of work, and you get the opportunity to put some anti-sieze on them in case anything ever comes up, you eliminated the risk of snapping a stud.
    • I let the dealer do every other oil change simply so they can rotate the tires, which is a pita at home.
    • I addition, I won't have a pan full of fluid sloshing around to get all over the place.   I am putting on the Dorman pan with the drain plug. It looks like it is around the same height. I have one of these guys to make life a lot easier.   https://www.amazon.com/dp/B09CDXJCCT?ref=fed_asin_title&th=1
