2010 Sierra 2500 6.0l Oil Pressure?
What's the average oil pressure during regular driving and under full throttle?
Anyone?
Call you dealer and ask them to print you a sheet off with numbers . .I took mine in with that very question as I thought I saw it fluctuating wildly at a red light. They printed off a list of RMPs and appropriate Oil numbers for me . . .
    ballencd
    ballencd
  • Who's Online   5 Members, 0 Anonymous, 713 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
