Driver Door Speaker Is Not Working
I tried doing a search on here to find if someone else had this problem and I can't seem to find anything (probably not searching right). Anyway, my driver door speaker does not work anymore and I don't know if maybe some wiring is off or if it needs completely replaced. Is that something I can just pop the speaker cover off and check? Sorry, I don't know much about this kind of stuff! Oh, I have a 2000 GMC Sierra 1500 regular cab if that helps.
Yep check for pinched wires going to the speaker as well. The harness could have become unattached, but likely the thing has just quit and you need a replacement. Excellent time to upgrade to some better speakers.
  • 2 months later...
I just replaced the speakers on my 2000 ext cab. On mine, the speaker grill was not removable without pulling the door panel. Pulling the door panel was not very difficult as long as you ID all of the screw locations and remove before prying. See the link below for step by step instructions.
http://chevroletforum.com/forum/showthread.php?t=21410
My passenger door speaker just stopped working in my 2007 GMC NBS
It was intermittent and now it just doesn't work Im gonna check the speaker it self and then I guess the wires at the radio??
94000kms out of a speaker isn't bad I guess.
    rayredbone
    rayredbone
  • Who's Online   3 Members, 0 Anonymous, 307 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
