Build Sheet By Vin?
Is there a way I can get a build sheet on my truck? The one I got from the dealer doesn't look anything like any build sheet I've ever seen, plus it's in French as the truck was located in Quebec!!
Hmmm, it came up no match!
Not sure what year truck you have but the database is sometimes lacking data on newer or older vehicles. In the glove box is a sticker with several 3-digit codes (RPO codes). You could match them against the attached file to see what options your truck has.
GM_RPO_codes.pdf
GM_RPO_codes.pdf
GM_RPO_codes.pdf
GM_RPO_codes.pdf
GM_RPO_codes.pdf
Yes, I have since tried that, actually. Thanks! Thankfully it all matches up to what the dealer told me. I don't trust anyone, hahahahaa!!
  • 1 year later...
Just wondering what happened to the above mentioned source "compnine" I used them on several different occasions now they are defunked? Anyone have another good source?
  • 6 months later...
