Bump/shutter When Cutting Off Engine
For the past couple of days, my truck seems to shutter or shake noticeably for a second or so when I turn it off. Seems like I can here a slight "bump" maybe on the last couple of strokes of the engine. At its worst, it seemed to shake the cab ever so slightly. This is a brand new 2010 Sierra with the 5.3. Anyone ever noticed such a thing? I did wash the exterior of the truck yesterday -- not sure if this is significant or just a coincidence.
Thanks alot.
    Brendan C
    Brendan C
  • Who's Online   4 Members, 0 Anonymous, 1,193 Guests (See full list)
