Zone Offroad
Let me save you some trouble...
Get the 3" body lift and a 1.5 or 2" leveling kit with some 33x12.5 tires and call it a day.
If you get that 3.5" combo kit you're going to spend a lot of time installing a 1.5" body lift where you could have spent about the same amount of time installing a 3" body lift instead. And trust me... you will want that extra height in the very near future.
IF you do get that 3.5" combo kit, dont forget to add $50 for the rear bumper brackets (its an addition on the "accessories" tab)
yup
yup
how do you like the rough country kit with the zone body lift? i also looked in the rough country kit
yup
I love it. Haven't had a problem from either kit. Most levels and bodylifts are all similar but I went with RC level because alot of people here recommended it and had a better design. As for the Zone body lift I went that route because I originally was going with BDS till they told me they no longer made bodylifts and sold their design to Zone. That's why I went with them and couldn't be happier. Performance Accessories also makes a pretty much identical bodylift and they are a good company too.
When you guys are putting these three inch BL on these NNBS trucks does everything thing go back to the orginal positions.IE: gas tank filler, all the other cables and hoses and harnesses? Im wobbling on 1.5 or 3.0 kit based on this. I already have 1.5 level
Just an fyi... on this forum we're doing away with the term "nnbs". try using "gmt900" when referring to the 07+ platform.
as far as the body lift.... yes everything goes back to where it should be.
only thing i dont recommend doing is the spare tire mod via the Zone instructions. If you download the PA instructions they have a method for retaining the oem spare tire access.... no parts are needed.
It should go back into stock place with the 3 inch as well? even with a little bouncing like when driving up north it wont extend it enough to pull anything?
