Transfer Case Leak
What is the best way to find a leak in a transfer case. I have a leak in my T-case and oil was on everything cant really pin down where its coming from. What is the most common leak on them.. I have a 95 GMC 1500 with a 5.7 Automatic.
thanks B
You can clean it really well and then look for the leak.
Or you can clean it and add a dye that will aide you in locating it
Check all seals. There has been a problem with a hole being worn in the case by moving parts also
on the rear half but just sprayit down with brake clnr and then go for a quick drive after you top up the level,or have a pro diagnose it
Search "pump rub" and see if you have a leak caused by the oil pump rubbing thru the case.
I have dealt with this and your options are replace the rear case half and use a case saver while it is open. Or you could use some JB Weld for a quick fix, may or may not last.
  • 1 month later...
    Patrick Fergy
    Patrick Fergy
  • Who's Online   2 Members, 0 Anonymous, 1,046 Guests (See full list)
