Water Pump Gasket Replacement 2004 Suburban
awsum00z71
I have the dreaded water pump gasket leak on my 5.3 on the drivers side. Noticed drips on the garage floor a month or so ago. Any helpful advice before I tackle this job? I plan to go ahead and replace the water pump since the Suburban has almost 80k on the odometer. I'm going to replace the thermostat too.
I checked out one of the pumps at the parts store and the gaskets included with the pump looks like a "cork" type gasket. Should I use another type of gasket? Any known problems with bolts snapping off when taking them out?
How long does the job typically take? I replaced a water pump years ago on my '82 F-150 with a 302 in it. That was quite a job, this one seems a little bit easier?
Thanks in advance for any advice.
Rick
    bellssn690
    bellssn690
  • Who's Online   4 Members, 0 Anonymous, 705 Guests (See full list)
