Stuck Third Row
does anyone know how to get the third row for a 2001 yukon xl unstuck. the seat is in the upright position but only the driver's side latches are engaged. lever 1 for folding the seat only goes about half way up.
Any thoughts would be appriciated.
k
    Brendan C
    Brendan C
  • Who's Online   4 Members, 1 Anonymous, 1,194 Guests (See full list)
