Need Help
mark1223
As some of you may know, from my other questions, I have the pulse. I pulled the wss off both sides, replaced the right one, because it was seized in and broke on me. I cleaned the mounting surface, now does it have to be bare metal, or a little rust? I put them back in with bearing grease on them and still get the pulse, but its not as back. I checked them with a meter and got a good reading. Any help is appreciated. Thanks
    Brendan C
    Brendan C
  • Who's Online   4 Members, 1 Anonymous, 1,194 Guests (See full list)
