Kicker 750.1
Selling my kicker 08zx750.1.. works perfect selling my truck due to economy and job loss.. paid 450 in 2009 selling for 250 OBO!! will post pictures!
shoot me any reasonable offer!!
    Brendan C
    Brendan C
  • Who's Online   4 Members, 1 Anonymous, 1,194 Guests (See full list)
