Tpms Bypass?
capstone-ed
Is there anyway to turn the tpms off? The light is starting to bug me
put some black electrical tape over the dislpay
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 240 Guests (See full list)
