Engine Swap
sorry if im in the wrong section did not see vans, i have a 2001 gmc 2500 van with a 4.3l, motor is done cant find another used 1 if so to pricy, found tons off 2003 to 2007 4.3s, what would be the changes in these engines, what do i need to do to make it work in a older van thanks guys
I'm no expert on the 4.3 but I didn't think they changed those along the way. If you pull the 8th character from your VIN, that is the code for the motor. Find a vehicle with the matching code and you should be set. You may also want to check in with the gang at the Engine Tech forum down the line.
--Mike
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,079 Guests (See full list)
