Transmission Pan
Sometime soon I am planning on getting a better tranny pan for my truck. I can't get a B&M one because of clearance issues with the exhaust (so the B&M guy said). Anyone with the 4l60E tranny got a deeper pan that fit with without any issues? I have a 2006 crew cab with 5.3L if that makes a difference on factory exhaust placement.
Will Mag-hytec fit or is there a cheaper solution? Don't know many companies personally that make tranny pans, so help is appreciated.
I have a Mag-Hytec on my 2005. It fits fine. Because it is deeper you will have to take the exhaust loose to get it into place, but once in place every thing clears. I would assume the B&M would be the same. It has a nice drain plug with a magnet on it. The one problem is when you want to change the filter the exhaust will have to be dropped again.
LOL. I love how you southern guys say things like "just loosen the exhaust". I live in Wisconsin, there is no such thing. We have to torch bolts to loosen. Gotta love snow and salt, really makes fixing things a pain.
Hint: MAKE SURE YOU DON'T UNPLUG THE SOLENOIDS while reinstalling the pan it is easy to do unless you take the exhaust off. I did my 2000 Silverado last summer. I could not get my exhaust off (see above) and knocked a wire off. Of course I didn't know until I was done, and didn't have 1st gear. Had to redo it, and had a friend pry the exhaust done a bit with a 2x4. Oh joy.
Salt, Rust????? Wow, yea the south is good for keeping a vehicle somewhat rust free..... :D Most exhaust manifold nuts just apply a good penetrate oil a couple times and the impact will bring them with ease.
I was handed a bottle of BG In-Force several years ago to try, of ALL the penetrate oil I have ever used that has to be one of the best of them. For those of you who have ever pulled a hood up on an old car and had a problem getting it to close..... I had this happen on my 1949 F-1..... The hood hung wide open and would not budge.... I sprayed the pivot points of the hinges with this, the rust ran out of the hinges, just like it was water and they have worked like brand NEW ever since.... I have gone through many bottles of this stuff since. I make sure there is always a back up bottle on the shelf just in case I need it.
Jbo
    appletrav
    appletrav
  • Who's Online   1 Member, 1 Anonymous, 467 Guests (See full list)
