What Do You Think?
hi i am new to this site, and i am a chevy/gmc guy, all i haved owned are 80s, and one 1994, all were tow trucks, now i just bought a truck off a guy, its a 1988 gmc 2500 ext cab long box, the rear end was ripped out and replaced with a dully rear end. has the fender flares. know the front end is the same, 6 bolt, the back is 8. it has a 305 5.0 litre engine with TH-400 3 speed transmission. The transmission is slipping and it doesnt go in reverse, im going to change the transmission, this week, and i need some help. I know the cross member, that holds the transmission mounts need to be cracked loose and taken off. (4). from there i forget??? also i heard you have to mark the fly wheel?? anybody who can tell me the steps... thanks and cheers!!!!
Here is what it looks like now....
2000 Grand Prix GTP-4 Door-315km
1988 gmc c3500-tow truck
  • 3 weeks later...
To be honest, your best bet is to buy a manual, one of the Chilton or Haynes manuals, where they give step by step. Just so you have a reference right in front of you, Otherwise if you miss a step or something, it may take a long time for someone on here to be able to figure out what happened and help.
I use these manuals for everything, and they have everything. They really do save lives and get trucks back on the road faster!
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
