2004 Silverado 2500 - Trailer Wiring Mess
I recently bought a 04 2500 and I'm trying to figure out the trailer wiring. It is not a 2500HD but it has the HD tow package. I'm assuming the HD package came pre-wired with a 7-way connector. Beside the hitch receiver there is the bracket where a 7-way connector would usually sit but it all bent up. I'm guessing the previous owner backed it into the trailer and smashed it up.
I was going to purchase the piece with the cover and just plug harness into however it looks like the cut the connector piece of the harness off as well. This isn't a big deal as you can just get a generic 7-way connector and hardwire the wires to it. My problem is that I don't know for sure I have found the correct wires.
I found a bundle of wires taped up near the spare tire. There is 5 wires and they consist of a large black wire, a smaller black wire and then a red, blue and green wire. Are these the wires I'm looking for and if so what color is what? I also thought there should be more then 5 wires. Does this mean I'm not pre-wired for a trailer brake controller?
Thanks!
your owners manual should tell you what color wires are for what...but in my 05 sierra half ton...i have a red wire,yellow,dark green,brown,white,light green, light blue and dark blue. Red is 12v power supply, yelllow-left/turn/stop, dark green is right/turn/stop. brown-taillamps, white-ground, light green-back-up lamps, Light blue- center high stop light, Dark blue-trailer brake
Thanks!
Both of my trucks have 8 wires at the back............ regular 7 wires plus the center high mounted brake light...... IDK what the colors are..... The 1/2 ton they go up in my back fender and my plug is in the bed.... Same with my 3/4....
Jbo
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
