A/c Compressor Not Engaging
slydog39
1999 Suburban 5.7.
My Ac was intermittently working recently--cold most of the time, then occassionally not cold at all. Obvious the compressor was not activating when it should. Had the system checked at a shop when it was working--all looked good. Suggested that either the low pressure/clutch switch going bad, or the dash switch was going bad.
Two days later it never cooled again. Replaced the low pressure switch, then the dash control panel. Neither solved the issue. Have checked the fuse and replaced the relay. Have tried to jump both the low and the high pressure switches to get the clutch to engage--no response.
What should be my next step?
