Aftermarket Exahust ------> Stock Exahust
Purchased a 2007 k3500 and it came with a cat back dual exhaust and it is to loud for me. I work nights, I am a volunteer fire fighter and drive through my neighborhood at all hours.
I want a quieter exhaust with the better stock hangers. The crappy universal hangers are being held together by coat hangers now.
Any suggestions?
I would like to get the original exhaust but don't want to even know what GM would charge for it. As well as the thing probably weighing a monstrous amount.
Thought about going to the exhaust shops and trying to hook a take off, but that may be a rare occurrence.
thanks
Dave
I would bet that if your a little patient and do a few searches online, some out there replace a brand new factory exhaust you could have cheap. Crips, I couldn't give my factory exhaust away when I switched.
Good luck :D
why not try some junk yards and see if you can find a truck similar to yours and just cut the exhaust off? or go to some custom exhaust shops and keep tabs on what goes through?
Find a good exhaust shop. I use a real good one where I live. They have built 4 different system for me. Most recently they built me a 3" single side exit system with a flowmaster 50 series muffler(which is really quiet) for $270. Much cheaper than buying any system. That price included the cost of the muffler. Just find a good exhaust shop and they can build you a system and put a quiet muffler on for a reasonable price.
You could just switch out mufflers... pretty cheap, the dual's are not the source of the noise, it's the mufflers, or lack of them thats making it loud.
go to an exhaust shop and tell them about your issue... you could get a large cased Magnaflow to replace whatever it is you have now and it would quiet down the motor dramatically.
    bellssn690
    bellssn690
  • Who's Online   3 Members, 0 Anonymous, 905 Guests (See full list)
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
