Under Seat Storage
I found this box at Wal Mart for around $10 bucks. I bought one for each side and the fit is excellent. Stores tow strap, tie-down straps, jumper cables, hitch, tools, etc. What do you think?
Well I discovered I already had that same box at the house.
It does work perfect. Thanks for the idea. I've been trying to come up with something without having to buy that under the seat storage bin and this works great. :driving:
:driving: I didn't even think about the towel, thats the cheap carpet protection until I can afford the Weather Tech mats. Three grandkids tromping in and out needs some kind of protection, don't you think?
    Gkistler
    Gkistler
  • Who's Online   2 Members, 0 Anonymous, 893 Guests (See full list)
