'09 Z85 Part Numbers?
my truck is supposed to have this installed. had to drive a rental today that also listed that suspension as being installed and it seemed stiffer than my truck. my truck is an '09 WT 4x4 reg. cab short bed and the rental was an '11 LT 2wd crew cab. the rental also seemed to sit taller. would like some help with shock and spring part #'s.
Post the VIN's from each truck and I can look them up,The shocks and rear springs should be the same part numbers,the front springs are probably different.
Keep in mind,Its hard to compare the ride and height difference of a reg.cab-std.bed 4x4 to a crew cab-short bed 2wd truck,although you would think the 2wd crew would ride smoother than yours.
I can verify you have Z85 on your truck,But I need the VIN of the other truck to verify what it has,and to compare part numbers.
I didn't write down the rental's VIN, but I wrote down the part numbers off of the actual shocks.
Ff Shocks : OE 1556120954599
Rr Shocks : OE 1544520955410
Those are production numbers from the manufacturer,Unfortunately I can't cross those over to GM part numbers.
    250.3k
    Dad X MTB
    Dad X MTB
  • Who's Online   2 Members, 0 Anonymous, 378 Guests (See full list)
