Chevy 7" Drop In Rear Help?
just did the mcgaughy 4-7 drop on my 08 chevy ..front is fine but the rear rides like crap .. rear bounces alot but doesnt bottom out which is good cause of the notch .. any idea what i can do to fix the bouncy feeling? without bagging it . bag helper kit or special shocks ? would appreciate any input thanx again
are you riding on stock shocks? if you are, they are too long you need new shocks for your drop
just ordered them today ... hoping that would do it .. bought the shock extenders initially for the factory ones ..guess that all comes out with the new ones? will that fix my issue u think ? thanx
im pretty sure that will help a ton since the stock shocks are bottomed out with your new rear drop.
what shocks did you go with?
edit: zembonez beat me to it
belltech nitro 2s or something .. from stylin trucks ..
what shocks u guys running?
Good choice. Btw This is a great site but there are only a handful of dropped trucks on this site.
You should check out gmfullsize.com it has more info on lowering trucks. Just FYI you gotta have thick skin on that site. :D
thanx for the heads up...what shocks u running on yours? how is the helper kit work out for u
im running belltech street perfomance shocks. the helper bags help a lot when i haul stuff in my bed, it also helps with the bottoming out since i dont have a notch on mine.
    Dom Colussi
    Dom Colussi
  • Who's Online   5 Members, 0 Anonymous, 586 Guests (See full list)
    • *Your
    • I'd guess that it's because they are Mann-Hummel filters since about 2016, they own Wix and are mostly all made in China now.
