Water Sound Inside Of Cab
i have a 1991 chevy fullsize 4x4 pickup regular cab 8 foot bed with a/c i have a strange sound inside the cab of my truck when ever i move the truck it sounds like water splashing around behind the dash on the pass. side is there any drain holes or plugs that i can look for i just dont want to have any other problems come winter time
leaky heater core? smell coolant?
maybe its blown and the fluid is trapped somewhere, although it should pour out from under the dash. do you still have heat?
also on the older trucks i know that the A/C water drain can be plugged and it can back up into the fan shroud in some cases.
You have trapped air in the cooling system. Bleed it out and it will go away.
cool thanks i just did intake gaskets on the truck 3 weeks ago thats problly what it is .............. but the truck has great heat thats why i didnt think of the air in the cooling system thanks a lot
Curious, mine is doing same thing. I replaced all cooling parts during overhaul, except heater core. it was making that sound before and after overhaul. I noticed gunk in the new radiator afterwards and thought the heater core must be partially clogged causing the rushing water sound, so I'm planning to change the heater core and flush again. Just wanted to know if you "bled" the system and if the sound went away.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
