New Guy With A Tbss....soon To Be Switching To A Sierra
Knowklew
Hey guys, just wanted to say hello. I have been a member on tbssowners for a few years now and wanted to join up here now that I am considering a full size.
Currently i have a 2008 trailblazer SS AWD. I love the truck but I need something bigger and better for towing.
Looking for any input on where to find a good deal on a 2010 GMC Sierra SLE or SLT, CCSB, 4WD.
Also looking for good places to buy accessories, exhaust, lighting, bed cover, etc...
Thanks for checkin out my thread.
--Fred
Hey guys, just wanted to say hello. I have been a member on tbssowners for a few years now and wanted to joing up here now that I am considering a full size.
--Fred
Dont know if you want new but the GMC Dealers are giving away 2010 for a great price. I got mine for 5k off and 0% financing for 72 months.
--Fred
The trailblazer isn't great for towing? Enough power I would think. Change the gearing??
TBSS tows great... But if i want to go on a sled trip with more than 2 people the backseat is terrible for 2 grown adults.
Be sure to consider a 6.2 with the 6-speed or most likely you won't be happy after owning the TBSS :)
I am going to go drive a few trucks this weekend. both a 6.2 and a 5.3. GM has a college discount that can be added to the regular discounts. Since I am a graduate student I see this working in my favor.
From what I have looked at on the website, the college discount gives me supplier pricing which will knock another 4-5k off the price of the truck.
That adds up to almost 10k in incentives.
Hello & welcome. Sounds like you have the right idea - try driving a few trucks with different equipment & options. Find the one YOU like and make sure it fits for YOUR usage. Options vary, 6.2 vs. 5.3, 4-speed vs. 6-speed, cloth vs. leather, long bed vs. standard bed vs. short bed, crew cab vs. extended cab - each has it's merits and may handle differently.
--Fred
Roughly 6k towing capacity. And it's already got 4.10 gears.
Welcome to the forum Fred! :)
    AidenVorpagel
    AidenVorpagel
  • Who's Online   3 Members, 0 Anonymous, 1,317 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
