Easy Cheap Way To
I can easily fab the pipes themself before and after muffler or what not. but i dont know if that would help or change anything. I dont want to spend much cheata and i just want it to atleast not sound stock. definitly dont want it to loud. Just my buddys titian sounds great stock and i want that.
cut off the rear most resonator and put a 5" resonated tip on it.. any mom and pop muffler shop can do it, probably under $200
won't be too loud at idle, but will sound good under throttle and you won't get the droning sound from the AFM when cruising (hence the resonated tip)
hacksaw in the garage, crawl under and hack the muffler and res off...you will shake the windows driving around but it will be louder then stock :uhoh:
there are youtube videos including the one in my signature of side exit exhaust before rear pass wheel. i cut the muffler off with a hack saw... 2hrs later i was much happier, then i went and spent 60 bucks to have a piece of 3" stainless bent and welded on, make sure you unload suspension though so it doesn't hit the pipe, that is why mine isn't tucked up against the body.
