Bluetooth Question
When an incoming call comes in and I answer it, not only does the radio turn down but so does the fan if the AC is on.
Is there a way to program this so that doesn't happen? If somebody calls me in the middle of summer, I might suffocate :D
use the fan botton it will stay up after, so you'll survive:)
I haven't tried that yet, it just doesn't seem right. I guess i have an option to not answer the call.
I like the feature, keeps the noise from the fan on high from being on the phone. You can always push the button to turn it up
I think it only happens if the hvac is on auto. If its on manual it doesn't change.
My 2011 powers down either way.
x2 so does my 2010
yep, just use the manual fan button to bump it up a notch or two so it's not running wide open, but gives you a little more comfort.
common sense guys. It turns the air down a bit so you dont have all of the air blowing around causing it hard for the other person to pick up your voice. as soon as you hang up it picks right back up. or you can just turn it up yourself while still on the phone
    Patrick Fergy
    Patrick Fergy
  • Who's Online   1 Member, 0 Anonymous, 1,060 Guests (See full list)
