8.1 Knock Retard At Wot
i have a 2003 yukonxl with 8.1 and the allison. have diablo tuner custom tune.anyone know why i have knock retard on my entire wot log?have 0 kr on cruise logs.checked under truck for rattles but cant find any.has anyone else had this problem or know what it could be? thanks again
have you had the code p0332v
have not had any codes.but am corrected i did have some kr on cruise log as well.did notice small leak at exhaust manifold would this cause kr?
have you had the code pave
Run it with higher octane gas and see if the KR amount changes. Could just be the normal KR retard function. If it senses knock it will retard to prevent it from knocking. WOT, especially at lower RPM, is prime time for knock.
i only run 93 octane.. gonna tune back to stock and log with laptop to see if its just the custom tune doing it
Is it tuned for 93 octane fuel? What are the specs of the tune? Exhaust leak will cause false kr.
Have you refilled the fuel tank since this problem? Maybe bad gas. If your wanting max performance you could always put alky injection on it. :D simple install and cheap to operate.
    bellssn690
    bellssn690
  • Who's Online   4 Members, 0 Anonymous, 705 Guests (See full list)
