Wheel Question
Worktruck
Looking at buying wheels and tires from a local CL ad. Wheels are from an 08 or 09 Colorado 17". Tire size is right for me 265-70x17. Think I've done my research right and these will fit my Silverado. Just wanna make sure. Any input guys?
Our 1500 trucks came with P265's from the factory, not LT. Is the wheel center bore the 78.2 MM and lug pattern 6 x 5.5 or 6 x 139.7 mm would be my greater concern. Our stock 1500 wheels also have a 31mm positive offset. If the wheels meet these patterns then you should be good.
The wheels will fit and I suppose the tires would work but I tow a lot and plow so I really need LT tires. To bad too cause the Goliath wheels had Nitto Terra Grapplers on them with lugs and center caps all for $1000. Bummin at the moment.
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 240 Guests (See full list)
