Found the fix for this. Untightan the bolt just below top linkage on the steering column, turn assembly left to reduce space between the two linkage rods at the steering column, tighten bolt. Made a big improvement.
2024 l8t . Ac has never felt really cold even new. But lately it seems a little warmer. When it gets in the upper 80s and a little more humid it just does not keep up. And sometimes at idle it gets warm. My wife's 2008 envoy is better. My son's 2016 is colder. I have an apointment for a third try Monday the 29th at a third dealer to try and get cold ac before my warranty is out. The first two told me something about so many degrees under ambient temp blah blah blah seemed like they didn't want to mess with me. This was set at low. Max air fan speed high. 87 degrees and a little humid.
It isn’t all that bad in the world with purchasing power versus quality. My first car had just basic equipment. My oil choice was conventional oil. The life expectancy was around 100K miles. During that time you could expect to change all the accessories. Today with inflation you can buy the equivalent. It comes fully loaded with 4 doors. The life expectancy passes 100K miles replacing no accessories. If reaching that milestone is your goal you simply follow the recommended service intervals. If you want more miles simply do more maintenance. When in doubt you can check the internet or YouTube for information. The selling of any product hasn’t changed since the beginning of time. The power of the buyer has. The price of the product hasn’t changed much with inflation. The buying public wants more. Competition and the buying public has put the sellers in a box. The greed is on both sides. You can still get more for less. You just have to do with less. That used to be popular. The buying public has changed . It’s the sellers that are trying to keep up. As Grumpy tries to inform the readers in this case with maintenance. If you want more. More effort is required. That information wasn’t available this easily just a few years ago. I believe the public has more power. Getting information is easier.
Gentlemen, I'm new to this forum. My question is, I thought I have read somewhere that the rear wheel liners for 2024- 2026 GMC Sierra HD3500 DRW can/will fit the 2023. I can't seem to find that information again and wondering if anybody has any knowledge if these will work or not with the 2023? Part# is 84892542. Thank you for any information. The GMC parts counter wasn't able to give my any definitive answer?
