Mini Usb Connectors?
yam700
Hi guy's,
Just received my new 2011 chev express van. I was installing my xm radio and when I had the dash bezzel off I noticed by the right aux outlet their was a mini usb connector ( part of the harness). Also when I removed the radio their was another mini usb taped to the antenna wire. Does anybody know the purpose of these 2 mini usb connectors? I just have the base AM/FM radio.
not sure but can you post a pic?
Dash is all back together. I will try on the weekend to take a picture of both. They are just standard mini usb's coming out of the vehicle harness.
    Brendan C
    Brendan C
  • Who's Online   1 Member, 0 Anonymous, 1,065 Guests (See full list)
