Heating Question
I had my heat set to the floor setting the other night on our way to michigan, so it was blowing out on the floor, but it was also blowing out of the defrost vents for the drivers window, but not the dash defrost. i guess my question is does it always blow out the window defrost vents no matter what setting its on? or is some actuator sticking. sorry if its confusing guys! thanks and hope you all had a good thanksgiving!
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 1,119 Guests (See full list)
