NEED HELP FAST
I have a problem that scares me. three time now (in 3 months, 2 in last week) my truck has cut out when I hit the gas, then a second later picked up. this IS NOT the ordinary 700R4 lag, it almost died. Today when I slowed down, and hit the gas to pick speed back up the ignition cut out again, but before it picked back up and started going, there was a muffeled POP. not a gunshot sound, but a muffled pop I could feel. PLEASE HELP FAST!!!!
With the truck in idle, put your hand over the exhaust and check to see if you are getting a weak exhaust pulse.  If very weak, catalytic converter is plugged.  Also check rotors/plug wires, etc in your ignition system to make sure they are not causing the problem.  Is there a rough idle normally?  Have you lost power?  What other symptoms?
Try a new ignition module (inside distributor).  If it hasn't been changed in a very long time to never...the heat sink compound dries up and the module gets heat saturated.
The pickup coil could be it, but the module is two connectors and two screws as opposed to distributor removal for the pickup coil.  You can have the module tested or there are suppose to be testing procedures in the service manual.  But if this condition is while the truck is at operating temperature, the test will never find the module bad.
I am getting so many differnt answers I think I'll just call the mechanic. this dosen't happen a lot, it's happened 3 times in the last three months. I've got some people telling me its the fuel pump, and some saying somewhere in the ignition system.
    Brendan C
    Brendan C
  • Who's Online   1 Member, 0 Anonymous, 1,130 Guests (See full list)
