Pine Needles Getting Into Hvac?
I have to park my 2010 WT under a pine tree and I'm worried about pine needles getting down under the cowl vent cover and into the HVAC system. On some GM vehicles there is a fine screen below the cowl vent to stop anything getting into the HVAC box but none on my truck. I don't know why they didn't include a screen - it couldn't add $.25 to the cost of the truck.
Basically two questions, should I be worried in the first place? And what should I do about it if this is potentially an issue?
