Chrome Ballistic Jester
BigLoggerhead
I've been searching everywhere and have yet to find a new body style GM pickup with these wheels in a chrome finish. I'm considering buying these wheels and would really like to see what they look like on before I buy them. Hope someone out there can help me.
www.trucktoyzperformance.com
put the year and model, may take a bit of searching but i remember a couple trucks running those on there.
    President Roberto
    President Roberto
  • Who's Online   0 Members, 0 Anonymous, 255 Guests (See full list)
