Evap Line Fittings
mike g 09
I have a 2001 suburban with 5.3L lm7 motor in it.
I need to remove the evap cannister, as part of a fuel pump replacment jobsigh.gif.
I have needed to remove the cannister for a long time (ongoing P0446 code), but have tried to remove the fittings at the evap cannister by hand, but have been unable to do so.
Is there any trick to removing these fittings? They are black plastic, and look like they are designed to be squeezed while removing them.
I'll try to post a pic later, but if anyone has words of wisdom on their removal (or fuel pump replacement), I'm all ears....
thanks a bunch,
they are a bastard,if you have compressed air,try to clean as much crap out as possible and then try again,maybe abit of lube sprayed in to .
patients is a good thing to have ,!
try ford f150 fittings on top of the tank,they are worse,
good luck ,
    MANGOAL
    MANGOAL
  • Who's Online   2 Members, 0 Anonymous, 492 Guests (See full list)
