Zone 3.5 Install Notes
So ive recently installed the zone 3.5 combo and i have some notes to share
First the level kit. it is NOT like the RC kit. you can not install it the short cut way like the video.
The spacer has lips that make it impossible to pry into place. Even if you do get it in place the bolts are too long to put in upside down and will hit the drive shaft. You do not need to loosen the shock tower bolts though.
Body lift. For a CC there are only 3 spacers on each side. Instructions do not tell you there is a difference with the CC.
Drivers side needs to be jacked higher because there are metal cups on the budy....(Why are these there only on the driver side?)
To get the front body mount bolt on the passenger side out, i had to loosen the trans oil cooler and move it towards the driver side.
Those are the major points i can remember, i took pics but i lost the SD card somewhere between my camera and my laptop. :thumbs:
pics of the finished product can be seen here.
http://www.gm-trucks.com/forums/index.php?showtopic=124068
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,058 Guests (See full list)
