92 Gmc With 4wd Problems
Is there some aftermarket product that you can buy to replace the 4 wheel drive actuator for the front differential? I replaced mine last year and am having to replace the same part again this year. Is there a mechanical actuator out there to replace the electronic one?
I believe the 1 ton 4x4 trucks have an electronic stepper motor which will bolt in (comes with a shim), but you will also need the wiring harness to go with it.
GM sells it, I doubt you can find both pieces aftermarket.
Its hard to believe you need to replace your actuator so frequently.
My truck(1994ecsb) had 370+++ Kilometers on it, and still worked good. I only had to replace a switch on the transfer case in that time. And YES, I usd 4x4 all the time, year-round.
