Help! Chevy Power Steering Noise?
I have a 07 Chevy Silverado 1500 4.8L I just bought. It has 52K miles on it. But I hear a grinding in the morning and it sounds like my power steering. I am used to a Cummins, so I do not know if the Power Steering noise is normal. Is the noise common or is it not good. HELP the dealer says it is normal (since it is under warranty), but seems to loud for me.
I made a video, but turn your SPEAKERS UP: http://www.youtube.com/watch?v=ex7IMNIo1B8
Yes normal. Peg a power steering unit all the way against the stops either direction will cause this sound in almost every vehicle. Cold hydraulic fluid makes this worse.
You are not supposed to turn it all the way until it hits the stops and keep it there. It puts undue stress on the pump. Just go to the stop point and slack off from there. The pump is bypassing since it is at the end of travel and that is the sound that you hear. If that is the sound you hear all the time for just normal wheel movement I would change out the fluid and see if that happens again.
So yes that is normal for the PS at full lock in either direction.
    appletrav
    appletrav
  • Who's Online   2 Members, 0 Anonymous, 506 Guests (See full list)
