4.8l With 35'' Atz Gear Change
I owned a 2009 sierra 1500 crew cab with the 4.8L
My setup is
Airaid CAI
JBA headers
Hi flow Cat
magnaflow dual exit
6'' Fabtech
35'' ATZ
gear 3.42
My question is
witch one is the best for power and fuel economy the trucks it's my daily drive
stock 3.42 at 65MPH the RPM is 1714
35'' 4.10 at 65MPH the RPM is 1810
35'' 4.56 at 65MPH the RPM is 2013
35'' 4.88 at 65MPH the RPM is 2154
stock 3.42 at 75MPH the RPM is 1978
35'' 4.10 at 75MPH the RPM is 2088
35'' 4.56 at 75MPH the RPM is 2323
35'' 4.88 at 75MPH the RPM is 2486
do not forget my engine is the 4.8
... not sure of your question here...
but for fuel economy the lower the engine rpm, then the better highway fuel economy, keeping the engine rpm in the 1800-2000 range while cruising is likely optimum, and anything over 2000-2200 rpm then you are going to noticeable lose fuel economy
and for off-the-line torque, the higher the gear numbers the quicker the truck will be
... this might suggest that the 4.10 gears would be suitable for your needs
    CaptainDad
    CaptainDad
  • Who's Online   5 Members, 2 Anonymous, 612 Guests (See full list)
