My 5.3l Issues
First off, let me say that I'm extremely thankful for the 100k mile warranty and that I do love my truck. Here's what happened to me:
I had a transmission problem first. There's apparently some kind of "pump" in the tranny (according to the service manager where I get it serviced) that circulates fluid in an attempt to warm it up quicker. Anyway, this pump died so they had to replace it. Several days later, they finally got all the parts together and got it fixed. I shrugged it off. After all, 100k mile warranty, blah, blah, blah.
Two days after I got the truck back from the dealer, the CEL came on and it was throwing a P300 code. I shut the truck off and re-started it and the code went away. It came back a couple days later and then went out. I figured maybe I just had a short in the system somewhere until it came on and stayed on. I took it back to the dealer and had them check it and change my oil and the guy came into the waiting area and told me that my lifters were bad (read any of the AFM threads to find out what that's all about) and that he'd call me when they got the parts in to fix that issue. He finally called me about a week later and I brought it in. He called me yesterday and said that one of the rollers off of one of the lifters had broken off and screwed up the cam, though I'm unsure how that happens, exactly. I mean, isn't there a push rod occupying the space that something like a roller bearing would need to fall into the rotating cam? So now my truck is sitting at the dealer waiting for a new cam. There were no weird noises, no rough idle, no stumbling, no oil consumption issues... nothing. I didn't know anything was wrong other than the CEL and the P300 code, which can be any number of things.
Anyway, I've been a GM guy since birth (my Grandpa is a retiree and used to work the Corvette line in the 60s and 70s) and my other car is a 2010 Camaro SS, so I'm not giving up on the brand, but I'm thinking maybe I'd be better served with a 3/4 ton diesel. I don't know. I talked to the service guy about maybe swapping in a hotter cam and getting rid of the AFM, but then my warranty is voided and I can't really afford to drop another engine in the truck any time soon.
I know this is a pretty depressing second post, but I wondered if anyone else has had to replace a cam?
-Tim
Sorry to hear that. Like you said good thing for the powertrain warranty and hopefully you didnt get a lemon.
Back in the 90's while working for GM, I had a Cadillac that was brought to me with 1500 miles on the modular V8 that was in the front wheel drive models, which had a skip, and was throwing codes. It turned out to be a lifter and cam issue. When I pulled the Intake off the engine, I noticed one of the guides that was supposed to keep the lifters from rotating had been left off at the factory. The lifter on one cam lobe had actually been rotating, and wore the cam out, and broke the roller off the lifter as well. The roller has to roll up the ramp of the cam lobe, and if it breaks or gets turned sideways, it slides up the ramp, and wears both the roller bearing as well as the cam lobe.
Not sure how the AFM would affect that, or if it even would, but the roller can break on any roller lifter, and in fact if it had broken first to cause the problem, probably had nothing to do with AFM.
It sure is strange that both problems occured at roughly the same time for you, but I don't think they were related.
    • This is exactly the reason our EV has consumed so much of my driving. I don't want to fire up a cold diesel or gas engine just to drive 2 miles up to the store. It's arguably terrible for an engine. If I'm not driving at least 10 miles and don't need to do truck things, the truck stays parked.   Enter the EV. It's immediately heating or cooling the cabin as needed (heat pump). An engine doesn't need to warm up or be driven gently. I can tear off in it with ZERO guilt. Move the car 1/4 mile from store to store and not think "gee, I'm short-cycling a lukewarm engine".   It doesn't idle in a drive-through. Doesn't idle at stop lights. (OK, neither would the diesel, if I let stop-start have its way, but I don't).   Even moving it out of the garage to wash it... HA! It doesn't need to be started just to move 40 feet. I have cars that I will actually put in neutral and push (no start) in/out of the garage or shop if they absolutely HAVE to be moved. My nice Camaros.
    • Some trailer plugs don't work. This one worked for me. Been using it for two years no issues. Amazon.com: Reese Trailer Plug Adapter, 7-Way Male Plug to 7-Way Female Plug, LED Lamp Out By-Pass, Plastic, Black, Each : Automotive
    • Great video. I almost want to reserve one now.
    • I traced the atf cooling system in my 1500 and it comes out of the transmission, into the bar/plate liquid/liquid heat exchanger, as stated above.  Then it crosses over to the external thermostat/bypass and then  to the aux cooler in front of the main radiator.  Hence, on this routing, the PPE thermostat bypass eliminator is an $85 piece of bling that does nothing for reducing atf temps on this truck.  I think I'll temporarily clamp a needle nose vise grip on the coolant feed hose to the bar/plate cooler and see how much the atf temp drops.  With the use of ULV trans fluid, I'm not convinced running the trans cooler than OEM spec is going to be detrimental to the life of the transmission.    I found this interesting on the Dana/Long site stating that they make transmission cooling/heating bar plate heat exchangers.  I worked with Dana/Long on a few projects when I was at the gas powered fun factory. https://www.dana.co.jp/downloads/PTG/Long/Dana_TOC_SpecSht.pdf  Bar plate heat exchangers are just a stack of stamped parallel path fluid channels, assembled and vacuum furnace brazed to make the final assembly.  Want more cooling/heating, just stack more plates until you run out of package space.   Anyway, thanks for the info, much appreciated.
    • I have thought an EV might have some practical value in extending the life of the ICE members of ones fleet. Now....I'm convinced of it. I've been letting my better half access Raven (Mitsubishi Mirage) for her needs while Dizzy has been in the shop. Being the fuel freak I am and given the fact Raven is capable of over 60 mpg in clean air on a warm day I was taken back by the wife's ability to take a car that had used a half a tank of gas that to that point had returned a value of 57 mpg and return in with a decimating 51 mpg for that same tank in that same day in a 15 mile round trip of short hop errands and a stop in the drive through at Micky D's.  😱   Trust me on this. It would take the remainder of that tank driven on the highway to return that tank to just 54 mpg. This is not a Mitsubishi issue. This is an ICE issue that is magnified in vehicles capable of such high fuel economy values. On a percentage basis your 1500 does the same thing. Short hopping an ICE consumes a good deal more fuel and in doing so provides zero additional useable outputs. That entire volume of fuel is wasted in diluting the cylinder walls oil films, creating crankcase moisture and acid content and the resultant wear.    Enter the SLATE. All of that is avoided and the ICE's advantage in range and made useful at reduced wear for your ICE!   Kind'a cool.
