After driving back from South Carolina this morning, I can confidently say the unloaded ride is considerably better with the RAS installed than it was without it. The truck feels more stable, smoother over bumps, and overall more controlled. I wasn't expecting such a noticeable difference when unloaded, but so far I'm very impressed with the improvement.
I'd much rather them add back the foot well lights before the dang glovebox one. In the 2 1/2 years I've had my truck. I'd say the glovebox has been open about 10 times.
I'm guessing moving the headlight switch to virtual was for cost savings. The headlights are already controlled via the canbus so why not eliminate the need to manufacture a switch and take up real estate.
I prefer a physical switch but I also realize I don't actually use it 99% of the time.
The 1% of the time I do want it, I'm guessing it's a pain to turn the lights on. Probably 1-2 screens deep in the infotainment just like in the newer Colorados.
Purchased a 1965 GMC 1000 series with a manual 3 on the tree. The linkage is frequently sticking in 3rd, most often. As such, I'm considering going to a floor shifter to alleviate this linkage problem. I've been searching for a floor shifter, but am coming up empty. Hurst doesn't have a complete kit, you have to purchase the shifter and linkage separately, and I haven't found anything for a 1965, plus Quite expensive. I've seen recommendations to use Mr gasket, but they no longer make a 3 speed shifter kit.
Does anyone have any recommendations??
Mrob7
