How To Install An Amplifier?
tony890721
I have a 2007 Silverado Classic WT with a 4.3 Vortec and I had installed a 6 Cd changer radio which came from an Avalanche or a Silverado LT. The radio works fine but the volume is insufficient. You have to set the volume to about halfway to hear something. I want it to be loud, how do I install an amplifier for this truck? The radio has two female connnector ends I guess one is for the radio harness and the other for an amplifier. Please tell me what can I do.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
