Fog Light - Cargo Light Switch Wiring
So, my fog lights do not work, but the cargo lights do. The plug on the back of the switch has five wires (in oder from top to bottom)
Grey
Orange
Black
Purple
Blue
Can someone tell me which wires control which functions? I need to know which one sends the 12v+ to the fog light switch button. I think I am not getting power to the switch, but the fuse is fine.
Also, unless I did something wrong, there is no power across the fuse terminals either, but I have power a the relay.
Thanks
According to the schematic, there is no power on the fog light switch. The orange wire is a signal wire to the BCM. When you push the switch it connects the orange wire to ground, signaling the BCM to turn on the fog lights.
You should have power on one side of the fuse. If not you might pull the cover off the fuse block and look at the backside of the fuse panel. Have seen many times when a mouse gets in there and they chew all kinds of wires up.
I did get the schematics today, and it does confirm what you said about no power on the switch. That said, I have come to the conclusion that I need to look at the backside of the fuseblock. One question, how do I get the fuse block up to see the backside?
Does it just snap down, or are there hidden screws somewhere?
I pulled the fuse block and I do not see anything funny or abnormal under the block.
I was able to get 12v+ across the 15a fuse. I got 12v+ on the relay 30 pin to ground. Got 12v+ on the relay 85 pin to ground with the park lights on. However, nothing activating from the switch. Unless I am missing something, it almost appears that I have a bad circuit in the BCM or a bad ground either from the switch to the BCM or form the BCM back to the relay. Seems the next step is to check continuity along the path and be sure that I am getting a good ground through the system.
Any other thoughts?
8.1, I agree with you, but I have discovered a problem. It seems that I have 12v+ on the orange wire, switch attached or not. So, I seems that there maybe an issue with that circuit of the BCM.
Looking over the schematic, It looks like the BCM function is to route the coil of the Fog light relay to ground through the drk green/wht wire that runs from the relay (neg coil side) to the BCM. Could the BCM be taken out of the circuit and just run the orange wire form the switch directly to the dk grn/wht wire and attach it to ground.
Wait, if I did this, it would provide a direct ground for the Fog light relay coil, thus turning on the fog lights every time the relay is energized (every time the parking lights are turned on). So, a second switch would have to be installed to break the relay to ground connection (acting as the BCM, as that is the function that the BCM provides).
But, the fog light switch is grounded, so it the orange wire and the drk grn/wht were connected, then when the switch activates, it would provide the ground... Additionally, by removing the BCM, the logic that turns off the Fog lights when the high beams are on would then be gone, and I could have fog lights on anytime the park lights are burning..., regardless of high beam, low beam...
Does all of this sounds right?
I know this might sound like a dumb question but did you check to make sure your bulbs are not blown?
Of course, that was the first thing I did.... If there were blown, I would still get the little orange indicator light next to the switch, and I was not getting that...
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
