Time To Buy!
Jhz2411
With spring right around the corner, I have been searching for the right aftermarket wheel and tire package to purchase. This is going to happen with in the next couple of weeks. After doing a lot of research I decided that I am going to go with 20'' rims and 305/55/20 tires. I have a 2007 NBS Chevy extended cab with a RC leveling Kit. I have recently purchased the zone 3'' body lift and will be installing as soon as the weather gets nice. I just want to make sure that the rim/tires I go with will fit. I am defintley going with the NITTO's just want to know which rims. Also want to double check if this setup is going to fit.
Here they are. The XD Monster's are 20x9 with a 18 inch offset. The Moto Metals are 20x9 with a 12 inch offset.
Monster!! That setup will work very nicely and will look great. FYI, offset is measured in millimeters not inches. :P
^^^^^ I agree ^^^^^ Get the Monsters
    hotfish
    hotfish
  • Who's Online   6 Members, 0 Anonymous, 839 Guests (See full list)
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
