Tire Chains For My Hd
kurt1993
Anyone know a reliable brand of tire chains or where to get some cause im not sure where to go to get some. Im just looking for a little bit better traction in the snow....hopefully my front end wont get so bogged down when i plow with all this darn snow!
thanks,
-Kurt
I know you can get them for your tire size at napa for $89 per pair. I don't know much about tire chains, just that I have those and they work for me on my plow jeep.
Ok cool thank you ill check napa out and see what they have, know anything about recovery straps too? cause i bought one thats good for 7000lbs i think but id like to get one thats 20,000lbs+
I'd go with at least 20K I have a 30K that's 3"X30' i believe. I got it from 4wheel parts pretty reasonably a while back
sounds good thank you
    hotfish
    hotfish
  • Who's Online   5 Members, 0 Anonymous, 815 Guests (See full list)
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because it’s in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
