New to this site from Lubbock
dutch 99 chevy
Welcome to the site.  Hope you enjoy it.  Feel free to ask all the questions you want and jump in on any topic.  :lol:
By the way, your our 4000th member.  :thumb:  :uhoh:
Welcome... :cheers: Cool to see someone from sorta near... I live in Las Cruces and travel back and forth a lot to Artesia to see grandparents and friends... Close enough eh???
