04 Silverado Alignment Issue
Chevy8604
Hi Everyone,
I just purchased a set of Michelin x radial LT2 for my 04 silverado. I had my truck aligned yesterday at my friends shop and everything was okay, no pulling either direction and steering wheel was straight. Now its pulling to the left and the sterring wheel has to be held to the right a lil to go straight.
I have 120,135 miles on my truck. Both drive and passenger wheel bearings have been replaced. The rack and pinion was replaces and the outer tie rod ends were replaced. Also all the shocks have been replaced. All the ball joints are good and so are all the control arm bushings. We checked my front end yesterday before we did the alignment and it's tight.
My truck is 4x2 and its has the Z85 smooth ride suspension
Any help would greratly appreciated
Thanks
Joe
Hi Everyone,
Thanks
Joe
Switch sides on the tires. See if the truck pulls in the opposite direction. You may have a bad tire.
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 1,105 Guests (See full list)
